Cooling setup for blower applications.
Old Jul 21, 2006 | 02:21 PM
  #16
Ponyhntr's Avatar
Re: Cooling setup for blower applications.
Originally Posted by blown383
Ponyhntr - Did you get custom intake piping done for the intake?
-B
Yeah, a guy at the shop I work at made it... it's a 3.5" dia. 90* tube, and a 3.5" 45* tube butt-welded together, then powdercoated black. The only way that it works is because I don't have ABS anymore. The elbow is a TFS.
Old Jul 22, 2006 | 11:17 AM
  #17
BadgeZ28's Avatar
Fingers crossed. I am hoping I can get by with a 15 inch Spal pusher mounted on the front driver's side and a 14 inch puller on the pass side using a powerdyne? CFM flow should be over 4000 if you can believe their numbers.
Old Jul 26, 2006 | 03:06 AM
  #18
AmericanMuscle33's Avatar
I'm seeing way higher temps since my s/c install. I'm running a EWP, 160* stat, fans are programmed for 165*, no a/c, and water wetter. It's been 100-110* here this last week, and during the day short jonts 'round town I'll see as high as 215-220's in traffic at the water pump according to my scanmaster. If i get on the throttle even on the freeway they'll creep up to the 230's. Before the S/C and w/ac i could almost never get above 180's 190's. Even tonight in the cooler air (60's) it never got below 195, and I saw as high as 215. I really don't want to blow money on a new Radiator right now, so I'm thinking 'bout trying upgrading the fan setup...always usefull down the road...
I blame my underhood temps...it's an inferno in there...I mainly blame this on my Hooker Super Comp Headers that are NOT ceramic coated, only painted. They seem to pump out heat like crazy...anyone else have this problem?
Old Jul 26, 2006 | 09:43 AM
  #19
Kevin Blown 95 TA's Avatar
Maybe you could get a cowl hood and get that heat out of there. Or run mostly water & water wetter & less antifreeze. Coated headers are one of the best things ever invented IMHO.
Old Jul 26, 2006 | 12:06 PM
  #20
BADST95's Avatar
Talking Re: Cooling setup for blower applications.
My car runs pretty cool. 180-185 on the highway. 220 in stop and go. But I certainly don't like to drive it when it's 95 degrees with the A/C on in stop and go traffic. If it's that hot, I'm on Lake Michigan jet skiing. Evans Cooling is suppossed to be the cat's meow. I'd love to try it to lower the temps a little bit, but it's around $30 a gallon.
Evan's cooling
Noct
Jul 14, 2015 01:18 AM
MadMav
May 25, 2015 09:35 PM
May 1, 2015 01:14 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
