Compression Ratio???
Old Feb 23, 2009 | 03:23 PM
BLWNLT1's Avatar
How do you figure out what compression ratio you will have.
Old Feb 23, 2009 | 03:30 PM
ak95ta's Avatar
https://www.camaroz28.com/calcs/index.shtml
That and more.
Old Feb 23, 2009 | 04:58 PM
boosted-lt1's Avatar
Yup. Just find a calculator you like using.
It's also important to understand fundamentally what a static comp. ratio is so that you know how stroke, gasket, piston relief, piston deck height and chamber cc changes affect the ratio.
CR is volume above the piston at BDC divided by volume above the piston at TDC - or a volume ratio.
The only thing I noticed in the the link to the one on this site is that it doesn't take into account gasket bore dia. separately. For a Felpro 1074, the gasket dia. is 4.060", so you cant assume that dimension is simply bore diameter.
I've been using this one lately:
http://www.csgnetwork.com/compcalc.html
-Scott.
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
surreybrad
Sep 29, 2015 09:00 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
