Cometic Gaskets
Re: Cometic Gaskets
Just make sure you don't get your quench greater than .070 . Thick head gaskets are the worst way to lower your compression. If your engine block is still at the stock deck hieght (usually around .025) then you wouldn't want to use a gasket any thicker than .045 .
WobblySausage
Oct 7, 2015 02:44 PM
