Clutch for Supercharged motor?
Old Dec 16, 2003 | 05:20 PM
racr4jc's Avatar
What clutch would be best to go with on an LS1 street car with a Vortech kit?
Old Dec 16, 2003 | 05:54 PM
97TA-WS6-Con's Avatar
well I'm not sure about the LS1 but I'm the same the options are the same for the LS1 as the LT1.
Here is a list of all the possable alternatives that would be up to the job in that you can be cnfident that oyu won't have to do it agan.
1. Mcleod Street Twin.
2.
Ummmmm. I guess thats it.
Old Dec 16, 2003 | 09:09 PM
RCF925's Avatar
97TA-WS6-Con, What he said, You will spend a little more upfront but they the best way to go and can handle up to 1200 HP, The peddle pressure is not much more than stock, Adjustable stainless master, If anything was to break, which I doubt you can just replace the parts you need.
Old Dec 17, 2003 | 09:57 PM
01SCSS's Avatar
I'm runnin the Mcleod Twin with a steel flywheel and it rocks, I'm at the 300 mile mark breaking it in and it hasn't chattered once. Pedal pressure is a little bit more than stock but not to bad. I have yet to really ring it out yet but I'm sure it'll hold. edit* It is more expensive than the rest but at least you won't do it twice
DirtyDaveW
Mar 15, 2015 07:01 PM
cyteone
Feb 7, 2015 06:04 PM
HectorM52
Jan 30, 2015 11:08 PM
CARiD
Jan 27, 2015 06:27 AM
