Changing plug wires with Vortech Supercharger?
Old Mar 29, 2007 | 05:18 AM
CrazyLT1's Avatar
Hey guys,
I have a 1997 Camaro LT1, with a Vortech S-trim supercharger. I need to change my #7 plug wire on the drivers side, because it got burned on the header.
Anyways - after taking a quick look - I was wondering if it is even possible to change that wire without taking the whole supercharger off!!? I see that it looks extremely tight around the supercharger brackets and optispark. But I also see that there are small areas where the wires can be ran through.
I am just wondering if you have enough room to get your hand in there and plug the #7 wire in, or do you need to take the supercharger and/or other things off in order to do this. That would be pretty ridiculous if you had to do that! Well, thanx in advance for the help guys.....
Old Mar 29, 2007 | 09:37 AM
OBE1 95Z28's Avatar
It's a bitch! You can remove the mounting bracket bolts to the SC and leave the head unit in place (don't completely remove) to give you some wiggle room to get to the wires.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
PCLZ28
Dec 24, 2015 05:19 PM
grgguy
17
Feb 23, 2015 07:57 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
