Centrifugal Superchargers for carburetors
Old Jan 15, 2004 | 01:48 AM
Wild1's Avatar
What is the success of centrifugal superchargers for carburetors? The roots style generates tons of heat but the centrifugal chargers are supposed to supply a "cooler" airflow to the carb. That was from the Vortech website.
Do they suck eggs or are they pretty good systems?
Old Jan 15, 2004 | 04:05 AM
97WS6SCharged's Avatar
The system itself seems to be pretty high quality, much like the rest of Vortech's line. I guess it just comes down to how well you tune the carb. and ignition.
Old Jan 15, 2004 | 08:33 AM
Sean94Z's Avatar
You need to talk to Scott at SD Concepts .. They specialize in carb'd blown cars w/ vortech and ati superchargers..
http://www.sd-concepts.com/
I think right on their first page there are some tests showing carb'd blown cars..
---Sean
Old Jan 15, 2004 | 10:40 AM
LameRandomName's Avatar
Car Craft has built a few different engine combinations with that Vortech blow through system and they seem to have had a lot of success with it.
Old Jan 15, 2004 | 11:42 AM
Wild1's Avatar
WOW! I talked to Scott for 30 minutes! He really knows his stuff. I've got some cash but I feel that I should save some more before taking his time with a build sheet. I can't recommend him enough.
I do feel bad to a certain extent because he spent so much time with me. But for what he's asking I don't have the $$$.
He did give a great perspective on the whole build. Running a blown carb set-up is different than EFI. Plus, the '69 has World II Iron heads. Scott also informed me the piston clearances are different on blown from N/A... So, converting to a blown set-up is much more involved that just bolting on a blower.
He also recommended pulling the heads and having him flow them and too de-stroke the engine from a 383 to a 355.
The fuel system is currently a Barry Grant but he recommends (Essex?) and a return line to have constant regulated pressure. Right now, my Barry Grant set-up only has a regulator with no return.
Also, by destroking the engine it will increase the Rod Ratio to a more desirable level.
However, I do notice that many members here go the 383 route and get blown. Hmmm... I would like to move out of the N/A motor... the lopey idle is really getting to me and the gas fumes are strong 106 LSA.
I guess there isn't a solution to go blown and get a 114 LSA on the carbed set-up... economically... without tearing apart the whole engine.
Old Jan 15, 2004 | 02:20 PM
Sean94Z's Avatar
Yea, scott is great, he spent close to an hour on the phone with me talking to me about the problems I was having.. He's a great guy.. Now to see if his products work <grin>
He was talking about SX fuel pumps, do a search, they make a lot of different fuel components..
You'll find a lot of arguments for the 383/355 build-up.. Fact is, Scott has some REAL fast cars, so, if you follow him, I don't think you'll be disappointed..
--Sean
Old Jan 15, 2004 | 08:44 PM
ToddR's Avatar
Scott is a cool dude.
The essex pump is excellent and I've driven with it on the street for 35k miles. Only trouble was a clogged filter. I had a guy weld on a sump to the stock tank and he poured in some sealer. The sealer broke loose and ended up clogging the filter. Swapped the filter out and I was back on the road.
Check the pics of the pump on his site.
Good to 1000hp each. Duals for over 1000hp.
http://www.sd-concepts.com/sdce_cars...challenger.jpg
Old Jan 15, 2004 | 09:11 PM
Wild1's Avatar
So, do you think the SX and regulator are worth the $500?
Old Jan 16, 2004 | 07:04 AM
ToddR's Avatar
Yes, they were to me. Now, ifin you are not planning to turn up the wick and stay around 450hp or less then mod a mechanical pump and forgetaboutit.
It's much better than messing with the holley color this and then having to buy a holley color that. End up paying the same amount anyway. Also, try buying the vortech stuff and the prices are comparable.
Old Jan 17, 2004 | 07:11 AM
MSM69Z28's Avatar
http://www.boostedhorsepower.com/Blowthru/Forums/
check out a new site dedicated to nothing but blowers and turbos through carbs. i run the vortech kit and it works great. there are a lot other options as well.
Old Jan 17, 2004 | 07:42 PM
Wild1's Avatar
Very cool! Thanks, I'll go through the threads soon.
Hal Fisher
Sep 30, 2015 09:03 PM
surreybrad
Sep 29, 2015 09:00 PM
HAWG
Sep 25, 2015 11:41 AM
DelSoto
Sep 19, 2015 05:31 AM
