carb, TBI, or MPI
carb, TBI, or MPI
Going to tear into the engine bay again this winter. I have a vortech blower waiting to be installed. Will be intercooled and i plan on running it at around 5-8psi....
right now i have a carb (holly) that is going to be way undersized (600cfm). Was going to pick up a blower calibrated carb off jegs or summit then i thought "why not go fuel injected"
is it worth the few hundred more to go TBI or a grand more and go MPI?Should i stick with the carb?
dream is by next summer to be in the 10's (will be happy wit 10.999)
BTW new heads are on the way also.
old car domain:
http://www.cardomain.com/ride/764516/1
old car domain:
Re: carb, TBI, or MPI
Blower + EFI is a combo made in heaven. Tuning a blower+carb is not a job for the faint hearted or the uninitiated. Unfortunately, an EFI setup is going to be a lot more than a grand over the price of a carb.
Rich
Rich
I vote for the carb. Rich is right, to set up fuel injection for boost is going to be way, way over a grand once you include the fuel system and tuning.
I just built a turbo setup using a CSU carburetor. The only change we made was moving the secondary linkage. It made anywhere from 480 (3.5 psi) to 930 hp (18 psi) on an engine dyno without any calibration changes to the carb.
BTW, there is a Mustang out there that's running in the 8's with a single 650 Holley and blow-through turbo.
Mike
Mike
most carbs that would do the job is about 750. TBI is about 1000 for everything minus the fuel pump and filter (already have) I would just need a return line. MPI is about 2500.
Mike
any recommendations? vortech has one but i forgot what it was...some holly that is 700 bucks.
Mike
