car idling low at times, stalls with clutch in
Old May 29, 2005 | 10:39 PM
SteveLT1's Avatar
title pretty much says it all. car is idling horribly, the idle is set to 950 in the tune, if you just turn it on and let it sit it will generally stay around that, sometimes dropping to around 600. once you start driving, as soon as you take your foot off the clutch itdrops right down and dies.
had this problem a few weeks ago and then it went away for a while - and now its back. tried a few different tunes as far as the idle is concerned and have the same problem with all of them no matter what its set to. Also the car wouldnt even start the other day until I took the map sensor out and reconnected it (no idea why)
if anyone has any ideas on what it could be would be appreciated
also if anyone knows someone near rochester, ny that can basically take a look at my car and get it all running right id be interested
ill post a datamaster log tomarrow
thanks
Noenav
Mar 1, 2019 07:38 AM
tds1213
Nov 27, 2014 12:55 PM
siguy
Nov 27, 2014 10:07 AM
USAirman93
Nov 24, 2014 03:37 PM
IRABuss
Sep 7, 2011 09:08 PM
