Can Vortech V1/2/3 be Clocked for Intercooler on '97 Camaor?
Old Aug 6, 2009 | 11:56 PM
Hal Fisher's Avatar
Can a Vortech "V" version SC be clocked to aim so that an IC can be routed without removing the ABS or AC? I've heard it can be clocked but might not be able to rotate because things are in the way on a f-body.
Hal
Old Aug 7, 2009 | 12:31 AM
Hal Fisher's Avatar
I mocked up 3" pipe and they do fit with one going over and the other under by the ABS. The bottom only needs to be 2.75" so it's even smaller than the pipe shown.
Excuse the BOV bung.
The pipe is 3". A system of 45 degree pipes and 90 degree silicone bends should actually fit. Not thrilled about the 90's.
It looks like I can do the "under" pipe from the SC with a 90deg on it:
Hal
Old Aug 16, 2009 | 10:45 AM
chasmosis1's Avatar
I deleted the ABS, but I had TC as well and it needs to be deleted just to get the compressor in there. I can say that I see absolutely no reason to do an AC delete on a factory designed SC system such as the V1 or V2. I have a T-trim with 3" into and out of the front mount IC. Doing a search on here will show how to route the pipng.
Chas
RUENUF
Mar 13, 2016 03:39 PM
RUENUF
Mar 13, 2016 03:37 PM
bunker
Jan 30, 2016 08:09 PM
boostedz28
Jul 3, 2002 03:24 PM
