Can someone explain MAF before or after blower?
Old 08-29-2005, 10:55 PM
DarkHorse's Avatar
I guess my research isn't netting much of a direct answer for me. What are the pros n cons of putting the MAF before or after the blower?
I've searched - seems kinda mixed. I'm set to install the MAF at the filter per Vortechs instructions - should I reconsider? I need this car to be pretty easy to tune for Bryan @ PCMForLess so if putting it on the discharge side is going to screw up Bryan then I would rather not do it.
Is there any performance benefit putting it on the discharge side?
DarkHorse is offline
Old 08-30-2005, 12:12 AM
OBE1 95Z28's Avatar
Re: Can someone explain MAF before or after blower?
The advantage of the MAF after the blower is that you can vent "unused boost" (TB blades closed after you let off the gas) to atmosphere instead of recirculating the boost (hot air) back to the intake side of the blower. This doesn't buy you much at the drag strip as your TB is open almost the entire time.
OBE1 95Z28 is offline
Old 08-30-2005, 05:27 AM
tici's Avatar
The MAF after the blower will keep the charge air cooler, some complains that it's noisy (not the MAF the ait that blows out of the bypass valve).
I'm too lazy to redo the piping or I'd try it (in stop and go traffic the IAT goes up to 140F easily)
tici is offline
Old 08-30-2005, 11:19 AM
Teufel Hunden's Avatar
Blow through or Draw through really boils down to personal preference. People have had great success running either setup. Blow through tends to have better throttle response (generally), but a draw through meter is easier to calibrate for, because you don't have to worry about what the piping infront of the element looks like. I could go on and on about the advantages of each, but if the instructions call for a draw through setup, do that.
Teufel Hunden is offline
Old 08-30-2005, 12:13 PM
gmr speed's Avatar
How much Hp you running? My choice would to be run SD, but you cant really get a mail order tune for that.
gmr speed is offline
Old 08-30-2005, 12:31 PM
DarkHorse's Avatar
Thanks for the replies guys.
I would guess my rwhp at around 330 based on my track times/mph/weight. I'm not sure what the supercharger is going to add - i've heard up to 130 to the wheels so i'd guess from 80-130rwhp is on the way with the kit installed.
Gonna plumb it per the instructions and i'll continue to research the rest.
Old 08-30-2005, 10:59 PM
CJ
CJ's Avatar
The main reason I relocated my MAF was because its less of a restriction on the compressed side. Ive never had any problems with tuning. Used the same tune running it both ways.
CJ is offline
Old 08-31-2005, 02:38 AM
tici's Avatar
Interesting: I was thinking that the MAF would have some problems working with hot air. Good that it works the same
tici is offline
Old 08-31-2005, 10:22 AM
The MAF doesn't care what temperature the air is, only how much is passing over it, and that it does so in the same way for which it was calibrated.
Old 09-03-2005, 11:51 PM
DarkHorse's Avatar
So you guys are using the stock maf correct?
Old 09-04-2005, 10:25 AM
tici's Avatar
Stock MAF, stock MAF calibration.
I only change the IFR table
tici is offline
Double aught
10-02-2015 11:29 PM
marlar98
09-19-2015 07:53 AM
tommalcolm
09-11-2015 03:39 PM
sleeperZ96BT
09-10-2015 08:01 AM
damnyankee36
09-09-2015 07:06 PM
Quick Reply: Can someone explain MAF before or after blower?
