Cam questions for lt1 w/d1
Old Oct 1, 2008 | 01:39 PM
97sstroker's Avatar
Im putting my car back together and was woundering if any one had any good cam suggestions. I have a 383 w/ AFR210 and a big Beck sheetmetal intake and D1 procharger, I have run Two different solid rollers already one just over 600 lift and 232/238 duration at .050, the second was 660/667 and 248/252 @.050 but ive decided to go back to a hydraulic roller and was looking for something that will pull in the higher rpm's and responded well to the boost. Any suggestions?
Danny
Old Oct 2, 2008 | 05:55 PM
streetbad's Avatar
How did the two cams you listed behave?
Old Oct 2, 2008 | 09:05 PM
97sstroker's Avatar
they both made good power but it was all up high so thats part of the reason im going back to a hydraulic, not to mention the larger one was only about .030 away from coilbinding the valve springs and id sure hate to hand granade a motor for just a few more ponies. Im sure theres good power to be gained from a good custom grind, but I dont trust a minimum wage technician behind a computer to tell me what my motor needs, Im looking for some personal experience or a good recomendation of an experienced cam grinder. Thanks
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
Noenav
Dec 6, 2014 07:35 PM
