cam question
cam question
Has anyone run a cam with positive overlap with their turbo setups? I have a cam with 5 degrees positive overlap and want to know if i can still use it for my turbo application. I will be using two logs with angles primaries to help flow and the crossover pipe will merge into a y before the turbo (I am not running the crossover thru the log). Here is my setup:
383ci LT1
AFR210's
T-76 Q Trim
Two 2.5" logs with 1 5/8" primaries
2.5" crossover
3" downpipe
I would like o make close to 700rwhp with 15psi (I also have a FMIC and alky setup).
383ci LT1
AFR210's
T-76 Q Trim
2.5" crossover
3" downpipe
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
