Cam question...
Old Jun 3, 2004 | 07:42 AM
RealQuick's Avatar
Cam question...
How can I get the 2214/224 cam to peak higher. I have heard it peaks around 5600-5700rpm. I would like to have it peak around 6k. Will having it ground straight up (instead of 2 or 4 degrees advance ground in) help in raising the power band higher?
Old Jun 3, 2004 | 02:16 PM
RealQuick's Avatar
Any of the cam gurus have an opinon? It shouldnt matter whether its a blower cam or not right?
Old Jun 3, 2004 | 02:30 PM
breakthelawinaz's Avatar
the easiset way i can think of is to run a higher rocker arm ratio, that should bump you another 100-200 RPM i would think...
Old Jun 3, 2004 | 02:36 PM
RealQuick's Avatar
I am already running 1.6RR's and the cam will have .565/.605 lift.
Rich was peaking @ 5600-5700 with 2 degrees ground into the same cam, so i wonder if having it groundstraight up will increase the rpms a little.
Thanks for your input.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
