Cam question...
Cam question...
How can I get the 2214/224 cam to peak higher. I have heard it peaks around 5600-5700rpm. I would like to have it peak around 6k. Will having it ground straight up (instead of 2 or 4 degrees advance ground in) help in raising the power band higher?
Originally posted by breakthelawinaz
the easiset way i can think of is to run a higher rocker arm ratio, that should bump you another 100-200 RPM i would think...
Rich was peaking @ 5600-5700 with 2 degrees ground into the same cam, so i wonder if having it groundstraight up will increase the rpms a little.
Thanks for your input.
