Boost question???
Old Aug 9, 2008 | 09:02 AM
bski224's Avatar
Boost question???
At what RPM point does boost really get going for you guys???
Old Aug 9, 2008 | 09:35 AM
jay_rich's Avatar
Well what kind of setup? Everything is gonna spool different.
Jay
Old Aug 9, 2008 | 09:54 AM
chasmosis1's Avatar
Agreed. With a Supercharger you will see boost continue to increase until you start overspinning it and loosing the efficiency. Turbos, however, are very different .
Old Aug 9, 2008 | 01:23 PM
bski224's Avatar
P-600B Hotcam/Head work etc.... Only pushing approx 6lbs
Old Aug 9, 2008 | 01:30 PM
StripedFomula's Avatar
p600b on stock internal lt1 with 8 lb pulley. start seeing a lb at 3000 and builds to 7lbs at 5800-6000
Old Aug 9, 2008 | 01:41 PM
bski224's Avatar
Excellent thanks dude!!! Is there a way to check my bypass valve while car is at idle??
Old Aug 9, 2008 | 09:39 PM
i am not really sure, i have mine set to vent to the atmosphere. i can plug and unplug the vac line and watch the arm move the valve open and closed positions
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jun 6, 2015 08:27 AM
