boost gauge reading vacuum, no boost at wot.
Old May 11, 2012 | 04:31 PM
xxteenobesexx's Avatar
Problem as stated, running off of PCV port. At wot it pegs zero, but no boost. Could I be bleeding boost through the surge valve? I have good vacuum at idle, and I believe that the valve is working properly. I would like to know how much boost I am making!
Old May 11, 2012 | 09:48 PM
Bigbadwhitey's Avatar
Re: boost gauge reading vacuum, no boost at wot.
I am apparently having this same problem
Im running an AEM boost gauge, how about yourself?
Old May 11, 2012 | 11:51 PM
97WS6SCharged's Avatar
You have the gauge feeding off of the port on the front of the manifold?
Old May 12, 2012 | 05:48 AM
The port right underneath the brake booster.
Old May 12, 2012 | 05:55 AM
I am running a sunpro
Sent from my PG86100 using Tapatalk 2
Old May 12, 2012 | 05:58 AM
DirtyDaveW's Avatar
That's the port I'm using too. When you say, no boost, do you mean you're car is boosting correctly but it's just the gauge is not reporting it?
I have both a regular analog boost gauge and the AEM truboost which is integral to the electronic boost controller. Both show my boost/vacuum correctly.
Old May 12, 2012 | 06:57 AM
Normally you put a check valve on that line to prevent boost from hitting the PCV valve and forcing its way into the crankcase. Have you tried moving the gauge line to one of the other ports on the manifold? I run my gauge and bypass valve from one of the other ports on that side of the engine with a T fitting.
Old May 12, 2012 | 08:49 AM
Kevin Blown 95 TA's Avatar
I run mine off that spot and there's no problem with it. I'd get another gauge - maybe a cheap diagnostic gauge or other low pressure gauge of some sort - taped to the windshield or something just to see what's up.
There was another guy a couple months back that had this same exact problem. I can't remember how/if he resolved it, though. He did test his gauge separately off the car and it seemed to show pressure, so you may want to try that. And make sure your hard line isn't kinked or leaky at the back of the gauge.
Garcia5
Jul 7, 2022 06:51 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
brentbrowning01
Dec 16, 2014 06:35 AM
blac94Z
Nov 24, 2014 07:12 PM
Antz97ZNJ
48
Jun 20, 2002 06:09 PM
