Blower Belt.... 42inchs 12 rib
Old Mar 9, 2007 | 03:44 PM
xxsaint69x's Avatar
so the question is where can i get one..the biggest one napa/carquest have is 41 inch -12 rib....and its a special order
any part numbers?
Old Mar 9, 2007 | 05:06 PM
cjmatt's Avatar
id run 2 6rib 42 inchers. i couldnt get a 42.5" 8 rib and im running 2 4's with no slip
Old Mar 9, 2007 | 06:24 PM
Lonnie Pavtis's Avatar
The 12 rib 42" is a special size only avail through ProCharger.
Depending on pulley sizes, you may be able to use a different size.
Old Mar 9, 2007 | 07:34 PM
xxsaint69x's Avatar
hey lonnie..i am using 1st and goal set up using the 3.70 pully...what size would you recommend?
Marcin
Old Mar 9, 2007 | 08:36 PM
Sean94Z's Avatar
I got a 42" 14 rib belt from NAPA and cut 2 ribs off
Old Mar 9, 2007 | 08:38 PM
xxsaint69x's Avatar
are you kidding me?! lol whats the part number?
Old Mar 10, 2007 | 12:02 PM
Sean94Z's Avatar
I am sorry man, I don't remember. I went to NAPA and the guy pullled the catalog out and we found it. My car isn't here, or I would look at the belt for you.
Old Mar 10, 2007 | 09:05 PM
Marcin,
I guess you could say I know your setup rather well.....
I was going to recommend the 14rib alternative as well. Mark actually did that before.
P/N's are the # of ribs plus the length.
That would be a 140420 or whatever you can get that is the closest. 14rib by 042.0 lg. is the way to read Gates Part numbers. Lengths vary slightly from this method, but only by fractions.
I think the 14 rib belt was slightly longer though.
Old Mar 11, 2007 | 12:13 PM
xxsaint69x's Avatar
Marcin,
so i went to gates website and the closest thing i could find was a K140429 MICRO-V CQBR...its a 43 inch belt...not sure if that will work?
In the 12 rib they have a K120410 MICRO-V CQBR which is only 41 inches...seems like they skip the 42 inch
Should i just suck it up and get the right belt from ATI?
and 1 more question..i noticed the SDCE idler pully on the tensioner was gettin little bit warn out...do you know where i can get a new one, and what size i should be looking for?
thanks!
Old Mar 13, 2007 | 09:47 PM
Mikael's Avatar
should be something like X42012 or X420R12- usually pretty easy to figure them out
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
bunker
Jan 30, 2016 08:09 PM
SpeedJunkee
Jun 6, 2015 04:27 PM
