Blow through MAF or not????
Old Dec 21, 2004 | 03:14 AM
Muskys SS's Avatar
Question Blow through MAF or not????
Is it better to locate your maf in the beggining of the intake tract before the blower or after the blower??? If it is located before the blower the maf will be reading incorrectly because some air will escape out the bypass valve or the blow-off valve when you let off the throttle. However if it is located after the blower and the blow-off valve it will correctly monitor what is going into the motor. However I've heard that maf's are designed to monitor unboosted air which means that it will not read properly if mounted after the blower??? Does anybody have info or been through this scenario?? I know that some people use our GM LT1 maf's in their Eagle Talons or Eclipse's with the blow through setup without any problems. Will it function properly in our cars??
Old Dec 21, 2004 | 07:39 AM
SMOKNZ's Avatar
Re: Blow through MAF or not????
IT works either way. The MAF reads oxygen, so the compressed air just has more oxygen per unit of volume so the MAF still detects it as more air.
Double aught
Oct 2, 2015 11:29 PM
drt
Sep 27, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
