blow by.. rear seal reverse instal.. anyone?
Old Aug 16, 2006 | 09:27 PM
NC-LT1's Avatar
blow by,
pushing oil past seals and valve covers... has anyone considered reversoing the rear main seal to keep pressure in rather then let oil be pushed out and onto the flywheel clutch area? just curious.
Chris
Old Aug 16, 2006 | 10:20 PM
Lonnie Pavtis's Avatar
Re: blow by.. rear seal reverse instal.. anyone?
It is already designed to hold pressure. If you reverse it, the seal will leak worse. The only seal reversal I've heard of is when using crank vacuum pumps to keep the seals from letting air in.... they now make special seals for this as well.
Fix your blow by problem...... the seals will be ok.
Old Aug 17, 2006 | 12:08 AM
Bryan 94 Z28's Avatar
Make sure you've routed the hoses correctly and that you don't still have the hose going from the side of the TB to the passenger's side valve cover.
Old Aug 17, 2006 | 11:17 AM
Sparkz28ss's Avatar
yeah...then run that hose from the cover to the inlet side of your compressor
Old Aug 21, 2006 | 12:00 AM
TransAm396's Avatar
what do you do with the hole on the tb?
Old Aug 21, 2006 | 10:12 AM
CJ's Avatar
CJ
cap it off.
Old Aug 21, 2006 | 02:37 PM
cjmatt's Avatar
Originally Posted by CJ
cap it off.
I layered mine with like 10 layers of duct tape and then ran a ring clamp around it. its held up fine so far
HectorM52
Jul 30, 2017 11:46 AM
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
PCLZ28
Dec 24, 2015 05:19 PM
BigWil
Mar 29, 2015 12:24 PM
redleader
Jan 22, 2015 12:05 PM
