Blow off valves
Old May 29, 2005 | 12:11 AM
blown69nova's Avatar
Blow off valves
I finally got my car going and put some miles on it, but when I got on it and seen 10+ psi of boost then let off it my intake pipe blew off. I am using a GReddy type s bov. What type/kind of blow off/bypass valves are you guys using? Do you guys think it could have blown off right before I let off the throttle?
Any ideas or suggestions would help. Thanks, Steve
Old May 29, 2005 | 04:30 AM
Lisa33's Avatar
Re: Blow off valves
we have 1 gready type S (copy) after the IC and the stock procharger valve just after the SC. 13-14psi, no chattering from the SC and no problem wídh hoses (only use the cheapest type of clamps)
Old May 30, 2005 | 01:14 PM
TransAmTONY's Avatar
Re: Blow off valves
Froom what i have heard tial 50mm BOV are good for our cars and can handle a lot of boost/horsepower... or if you wanted to go super huge you go with a gidzilla BOV but the are $$$$... my $.02
-Tony
Old May 30, 2005 | 03:10 PM
flusz28's Avatar
Re: Blow off valves
i running a 1G BOV - only caused me $10 bucks and it sounds awesome. i'm running 8psi.
Old May 31, 2005 | 04:30 PM
BADST95's Avatar
Smile Re: Blow off valves
Bypass Valve
Mine vents into the atmosphere.
Old Jun 1, 2005 | 07:27 AM
Ponyhntr's Avatar
Re: Blow off valves
Originally Posted by BADST95
Bypass Valve
I like!!
Old Jun 1, 2005 | 08:25 AM
flusz28's Avatar
Re: Blow off valves
it doesn't make noise like my BOV. does it?
Old Jun 1, 2005 | 09:40 AM
BADST95's Avatar
Talking Re: Blow off valves
It's a "little" loud.
Old Jun 1, 2005 | 02:05 PM
JZ 97 SS 1500's Avatar
Re: Blow off valves
Our experience with big boost the Turbosmart Megasonic and Tial 50 have done the best jobs for the $$. Their are other units out like the G-zilla and HKS racing BOV, but they are much pricier and you gain nothing.
Old Jun 3, 2005 | 08:49 AM
GotBoost?'s Avatar
Re: Blow off valves
I would upgrade the type S to a type R, the S is a 35mm valve, the R is a 47mm valve, it will purge/vent more pressure than the S. I am assuimg your turbo is pretty big.
malikot02SS
Aug 15, 2015 01:11 PM
350350
14
Aug 11, 2015 12:03 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
Noct
Jul 14, 2015 01:18 AM
