View Poll Results: Best stroke for DD blower lt1
3.480" stroke (355)
30.00%
3.750" stroke (383/385)
70.00%
3.875" stroke (396)
0%
Voters: 10. You may not vote on this poll
Best DD Blower motor stroke?
Old Mar 12, 2007 | 07:51 PM
VK's Avatar
VK
Post Best DD Blower motor stroke?
Simple little poll. I've been going back and forth so many times my head hurts. I need a final answer so i can tell VRE what i want.
VRE said to go w/ 3.750 stroke w/ min overbore
I've heard many times the 3.480 stroke will yield a thicker piston thus safer for a FI car with pump gas...
Again here is the plan..
Dragonslayer crank
H-beams from callies or Oliver
Diamond dished pistons with ~ 9.0 SCR w/ 54cc heads studded w/ cometic
4 bolt splayed w/ 4 bolt front main to help with blower pull
Double keyed crank
DD street car shooting for ~700rwhp .. 10s or HIGH 9s
(MIGHT try and shoot for 800-900rwhp in a few years)
Old Mar 14, 2007 | 08:17 AM
cjmatt's Avatar
talk to them about my setup. the driveability is second to none. Ive driven it 30 miles each way to work for weeks at a time sitting in traffic, freeway, you name it.
Old Mar 14, 2007 | 08:40 AM
VK's Avatar
VK
What do you have for a setup? Stroker? SCR? Cam? How much boost?
Old Mar 14, 2007 | 11:13 AM
joe-96z1le's Avatar
The rod length is going to be a factor in this also since it will affect pin location and crown thickness in the piston. I'm running a 3.75 stroke, 5.7 rods, JE Extreme Duty pistons, and only 10 over on the bore.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
transam_388
Mar 15, 2015 11:53 AM
