Anybody using an Ultradyne blower cam???
Old Feb 15, 2003 | 03:59 AM
96 WS6's Avatar
I have one and I don't know the specs... can I get the serial and ask for a cam card? Anybody use an ultradyne cam and have an comments good or bad about them? Dyno numbers and setup? Thanks.
Old Feb 15, 2003 | 08:52 AM
MEAN LT1's Avatar
Never heard of it. Who makes it.....comp?. You can always put cam doctor on it and figure out the specs.
Old Feb 15, 2003 | 12:50 PM
94LT1_89TTA's Avatar
I am not running one in my blower car now, but I would certainly have confidence in one if it were the right grind. I have run several UD's in the past on NA motors and have always been pleased.
I have a catalog. Post the numbers ground on the nose of the cam, and I will look up the specs.
Rog
95Z w/PD 12.02 @ 123.6 on Firestone SZ's.
Old Feb 16, 2003 | 04:24 PM
96 WS6's Avatar
Thanks for getting those specs... here is the serial:
395 Y^N
and on the other side...
284/288
8 3
HR12
and the one ur probably looking for...
G4548
Thanks again.
Old Feb 16, 2003 | 05:27 PM
The cam is a hydralic roller with a 112 lobe displacement angle. There are (2) different 284 duration lobes, and (2) different 288 lobes in the catalog. It could be either of them.
Seat Dur Dur @ .050" Lobe Lift w/1.5 w/1.6 rockers
284 218 .3280 .492 .525
284 230 .3533 .530 .565
288 223 .3533 .530 .565
288 234 .3533 .530 .565
If it is really a blower cam, then it is probably the 218/234 combination as all other combinations don't have enough as much dual pattern as usual for a "blower" grind.
Since the 218 lobe has less lift than the others, you should be able to tell if it is "that" 284 lobe using a dial caliper and comparing it to the exhaust lobes.
Unfortunately, that is as close as I can get you from the catalog.
Call them Tuesday (Monday may be a holiday), and give them the serial #, and they can tell you exactly what it is.
http://www.Ultradyne.com
Roger
Old Feb 22, 2003 | 12:46 PM
96 WS6's Avatar
I'm a bit new to this cam stuff... I'm not sure exactly what you wrote down means. Could you please clarify for a beginner real quick =) I know the basics (lsa, lift, duration) but which cam do you think would be the best for a blower? Whats the 218/234 aren't those two different cams? I know I probably sound stupid but could you please explain. Thanks.
Old Feb 22, 2003 | 05:11 PM
I was referring to a 218 intake lobe coupled with a 234 exhaust lobe on the same cam.
There is no "best" blower cam. It depends on too many factors to cover here, but in most cases a blower cam has at least 10 degrees more exhaust duration than intake, and most blower cams are ground with wide lobe separation angles.
Call Ultradyne and get the exact specs of that cam. You can't decide anything until you know that.
I am going to be in San Fran on business this coming week. I would be happy to meet you somewhere and discuss it. EMail me if you want.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95maroboi
Jun 7, 2015 12:18 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
