Anybody have a demon and procharger or
Old Jun 27, 2003 | 10:06 AM
SLO SS K2's Avatar
is there a problem? Demon says, they do not recommend using procharger with demon carb. Any idea why?
"Steve
At this time we do not recommend the use of any of our products
with ATI Procharger systems.
Thank you
Tech @ Barry Grant, Inc."
Old Jun 28, 2003 | 06:03 PM
MSM69Z28's Avatar
take a look at this forum for some blowthru tech.
http://www.boards2go.com/boards/boar...ser=huntracers
here is a forum post with someone that is running a centrifugal blower and a demon and made over 850RWHP. he used it with a vortech carb enclosure. that combination works. here is the link:
not sure about the procharger bonnet working with the demon, but i wouldn't see why not. actually, a better bonnet/hat like the CSU hat or Extreme Velocity can be used in place of the stock procharger blowthru hat and it will make a world of difference as well.
bottom line: yes, i believe you will be fine using a demon with the procharger set up. demon probably has not done formal testing and is hesitant on recommendation, but its been proven to work by others.
good luck.
mike
Old Jun 29, 2003 | 08:29 AM
SLO SS K2's Avatar
What I find most strange is that Vortech tests with a Mighty Demon and Barry Grant says it doesn't recommend using ATI? Needless to say, I have a Mighty Demon 750.
SPK
Old Jun 29, 2003 | 07:11 PM
89ProchargedROC's Avatar
whatever you do steve, dont use an ATI bonnet
Go over to the www.turbomustangs.com forum and look in the carburated tech section
They have a lot of blow-thru setups and know which ones work and why the cheaper ones cause issues
AviatorDave
Dec 19, 2016 06:35 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
95blkss
Sep 22, 2015 03:18 PM
95blkss
Jul 13, 2015 01:28 PM
jdelaprida
Jul 4, 2015 03:02 AM
