Any tips? P1SC
Old Aug 10, 2003 | 11:12 PM
steve10358's Avatar
3rd Gen Tech Moderator
Any tips? P1SC
So I have everything bolted up, except for the tubing. The guy I bought my kit from said everything should just bolt up, yet nothing lines up! What am I doing wrong? I don't want to buy a ton of extensions (fernco) if I dont have to.
Did anybody else run into this problem?
Steve
Steve
Old Aug 12, 2003 | 07:02 AM
steve10358's Avatar
Old Aug 12, 2003 | 06:59 PM
MattK's Avatar
Having just installed the p1sc on a 97 camaro 3 weeks ago, all I can think of is whuh? Everything pretty well fit in place for me, but then again, I bought my kit new. Definately had to clearance the ABS bracket, but that's really it. Other than the expected pita for hoses, everything pretty well fit, I honestly can't complain much.
Sorry, can't add anything at all for you. The fit should be a lot better than you mentioned, even though you can't expect OEM fit and finish.
Old Aug 13, 2003 | 04:12 AM
SloLt1Z's Avatar
My kit kit pretty much bolted in. Had to cut the air dam, move the air pump (to the trash), and move the ABS. It went pretty smooth. Which intercooler setup do and have?
Old Aug 13, 2003 | 07:08 AM
steve10358's Avatar
I have the two core. And while I adjusted things yesterday to work better- the sc outlet and ic inlet dont work very well with the stock, supplied elbow.
Steve
Old Aug 13, 2003 | 07:30 AM
MEAN LT1's Avatar
Steve
Sorry, your having such problems hooking the s/c up. You may also consider when you get everything situated to go front mount with that 2-core. I would hate for you to bottom out on that thing run into a hige puddle with the i/c sitting on the bottom of the car.
Old Aug 14, 2003 | 06:57 AM
steve10358's Avatar
Correct me if I am wrong, but wouldn't I need to either cut something or remove my fog lamps?
ALso- where did you guys find your tubing and hoses?
Old Aug 14, 2003 | 08:26 AM
BAD 97 WS-6's Avatar
If you have a TA and bought the Kit off of a camaro, then there is the problem. I had to cut my tube that comes up near the driver side headlight about 6 inches I believe. The camaros have that extra space over there because they do not have pop up headlights. So the tube that comes with the camaro kit is longer.
Old Aug 15, 2003 | 07:59 PM
steve10358's Avatar
Thank you! I ended up buying more rubber tubing at a truck store. Thanks!!
Old Aug 15, 2003 | 08:01 PM
steve10358's Avatar
another thing- how tight is the bend between the blower and ic inlet supposed to be? Mines not kinked, but man- it sure doesnt look good.
13qtr
Oct 28, 2016 08:11 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
autoxr166
Sep 25, 2015 04:21 PM
Godamnilovemy79
Sep 3, 2015 03:40 PM
colts0455
Sep 2, 2015 12:41 PM
