Any tips? P1SC
Any tips? P1SC
So I have everything bolted up, except for the tubing. The guy I bought my kit from said everything should just bolt up, yet nothing lines up! What am I doing wrong? I don't want to buy a ton of extensions (fernco) if I dont have to.
Did anybody else run into this problem?
Steve
Steve
Steve
Steve
Having just installed the p1sc on a 97 camaro 3 weeks ago, all I can think of is whuh? Everything pretty well fit in place for me, but then again, I bought my kit new. Definately had to clearance the ABS bracket, but that's really it. Other than the expected pita for hoses, everything pretty well fit, I honestly can't complain much.
Sorry, can't add anything at all for you. The fit should be a lot better than you mentioned, even though you can't expect OEM fit and finish.
Originally posted by steve10358
I have the two core. And while I adjusted things yesterday to work better- the sc outlet and ic inlet dont work very well with the stock, supplied elbow.
Steve
Steve
If you have a TA and bought the Kit off of a camaro, then there is the problem. I had to cut my tube that comes up near the driver side headlight about 6 inches I believe. The camaros have that extra space over there because they do not have pop up headlights. So the tube that comes with the camaro kit is longer.
autoxr166
Sep 25, 2015 04:21 PM
colts0455
Sep 2, 2015 12:41 PM
Thanks!!
