air to water I/C heat exchanger mounting???
Old Aug 5, 2009 | 01:37 PM
bowtiepwr's Avatar
>ok I decided to start working on this thing again...
I am using a B&M trans cooler with fan
to use with my 3 gallon fuel tank now used for the I/C...
and I/C from PTK
so where do I mount the heat exchanger?
and all the fittings are AN -12 with a Dayton pump.
Old Aug 5, 2009 | 06:51 PM
Hal Fisher's Avatar
I've heard of them going in the deep part of the trunk.
Hal
Old Aug 5, 2009 | 08:06 PM
bowtiepwr's Avatar
Hal
>I was thinking about mounting the B&M heat exchanger on the aft side of the radiator.
I think if it was in the trunk it would be loud and limited on the cooling.
Old Aug 7, 2009 | 04:30 AM
97WS6SCharged's Avatar
Get some flex hose and route the air from one of the AC vents to the trunk area.
I believe they generally mount the heat exchanger where your intercooler is located. How much room is there between the IC & the nose? I'm afraid to ask where PTK tells you to mount it.
HectorM52
Jul 30, 2017 11:46 AM
rjc1629
Jan 27, 2015 10:46 AM
95chwagon
Jan 13, 2015 09:19 PM
Jul 4, 2005 05:00 PM
BLOWNBIRD
May 28, 2003 01:02 AM
