air to water I/C heat exchanger mounting???
Subscribe
Aug 5, 2009 | 01:37 PM
>ok I decided to start working on this thing again...
I am using a B&M trans cooler with fan
to use with my 3 gallon fuel tank now used for the I/C...
and I/C from PTK
so where do I mount the heat exchanger?
and all the fittings are AN -12 with a Dayton pump.
Reply
Aug 5, 2009 | 06:51 PM
I've heard of them going in the deep part of the trunk.
Hal
Reply
Aug 5, 2009 | 08:06 PM
Quote: I've heard of them going in the deep part of the trunk.
Hal
>I was thinking about mounting the B&M heat exchanger on the aft side of the radiator.
I think if it was in the trunk it would be loud and limited on the cooling.
Reply
Aug 7, 2009 | 04:30 AM
Quote: I think if it was in the trunk it would be loud and limited on the cooling.
Get some flex hose and route the air from one of the AC vents to the trunk area.
I believe they generally mount the heat exchanger where your intercooler is located. How much room is there between the IC & the nose? I'm afraid to ask where PTK tells you to mount it.
Reply
Subscribe
