Afr 227
Old Mar 18, 2005 | 09:12 PM
J'S Z's Avatar
Afr 227
Hey still planning a 434 sbc and was looking at the afr 227 heads.I see they come in a standard exhaust & spread port exh.Are one of a benifit than the other?I tried calling AFR but they had me on hold so long I had to hang up.I was at work and they be closed by the time I get off.Will be using a F1 s/c figure I would ask you guys that have some experience.Thanks
Old Mar 18, 2005 | 10:24 PM
biggtime's Avatar
Re: Afr 227
Depends on what header you are going to use. Can you get a stahl pattern header for your car? if you can this is the way to go as you can use bigger primary tubes that will not block the exhaust port.
G-BODYT56
Jan 14, 2022 11:14 PM
RUENUF
Mar 13, 2016 03:37 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
FryedClutch
Sep 1, 2015 08:24 AM
bunker
Aug 21, 2015 10:21 AM
