Afpr
Old Mar 24, 2008 | 08:48 AM
Greg88's Avatar
Afpr
Hey guys with boost, can i use a metco?? Or should i go with a aeromotive? Thanks for the help Greg
Old Mar 24, 2008 | 01:21 PM
94SLUG's Avatar
Neither save the bucks use stock works just fine!
Old Mar 24, 2008 | 06:01 PM
Boosted_Z28's Avatar
Maybe I'm incorrect, but I don't believe that a stock LT-1 FPR will sense boost.
Old Mar 24, 2008 | 06:12 PM
boosted-lt1's Avatar
Stock FPR is 1:1 isn't it?
Old Mar 24, 2008 | 07:22 PM
Greg88's Avatar
I'm gunna be getting a wild deal on a Holley AFPR so i'm def going with that, hopefully it'll help out
Old Mar 24, 2008 | 08:08 PM
Greg-Just make sure it is "boost referenced" so it will increase the f.p. based on the amount of boost it is seeing, otherwise the motor will be going lean.
Old Mar 24, 2008 | 09:04 PM
Greg88's Avatar
I looked up them on summit and i think they only make the boost referenced ones for the LT1, but i'll double check into it. Thanks for all the help, its greatly appreciated.
Old Mar 24, 2008 | 09:14 PM
97WS6Pilot's Avatar
Yes the stock regulator will sense boost. It rises on a 1:1 ratio. So it should be at 43 at 0 boost and 53 at 10psi.
To the poster: I would stay far away from aftermarket fuel pressure regulators. If you need nonlinear(4:1 and so on) fuel pressure there are alot of people here that will sell you an FMU to use with the stock regulator.
Old Mar 24, 2008 | 09:42 PM
Funkybird's Avatar
So if the stock one senses boost then whats the point in buying a new one? All these people that have aftermarket ones pretty much threw their money away?
I'm in the market for one but if its a waiste then i'll spend my money elsewhere.
Old Mar 25, 2008 | 12:25 AM
97WS6Pilot's Avatar
Its a waste of money unless you are using bigger an style fuel lines. However the stock fuel lines have proven to be good to over 700fwhp. So yes there is no reason to buy a fuel pressure regulator unless yours is leaking or has gone bad.
Try a search on aeromotive fuel pressure regulators. Nothing but trouble and no performance gain.
Old Mar 25, 2008 | 08:22 AM
Greg88's Avatar
any one else's thoughts on this matter??
Old Mar 25, 2008 | 11:05 AM
94SLUG's Avatar
It's total waist, I used Aeromotive it leaked, never got more than 40psi...
Old Mar 25, 2008 | 11:47 AM
branland's Avatar
I was going to buy one until the dyno shop that tuned my car said not to use one. They make if very difficult to tune the car properly and they are not very consistent. I think his exact words were, “Slush box.”
Fastbird93
Sep 29, 2015 04:05 PM
Drtryder
Apr 22, 2015 04:17 PM
87Aerocoupe
Mar 20, 2015 01:23 AM
CobraEatr
Jul 24, 2004 11:37 AM
teke184
Jun 19, 2002 04:42 PM
