Advantage of Two??
Old Oct 27, 2005 | 11:25 AM
"White Knight"'s Avatar
Advantage of Two??
What is the advantage of a twin turbo setup compared to just a big single turbo?? Is it just the spool time that is different?
Old Oct 27, 2005 | 11:57 AM
will62085's Avatar
Re: Advantage of Two??
i went with a twin system for space reasons, and its just cooler i cant see any real advantage though... actually probably made it harded to fab everything, ide go single if i did it again
Old Oct 27, 2005 | 12:11 PM
Yea single would be easier to fab up. From what I have seen Twin turbo setup offers better low to mid power than single big turbos do. This is good for street driving when you are not screaming to redline racing. but if you are racing, where you keep rpms high(loose converter) a single works good.
I haven't priced turbos yet, but how much does the turbo you use in your twin turbo setup cost to buy seperately? I just which is cheaper 1 bigger turbo or two smaller ones? I assume single bigger one is cheaper.
Hey Will, did you relocate your alternator for those manifolds or does it sit above the manifold?
Old Oct 27, 2005 | 03:08 PM
will62085's Avatar
mine are master power t-70 units, and depending on where you get them they can be had for about $600 a peice.
alternator and power steering pump relocated to bottom passenger side of the motor
Boss002
Jul 24, 2015 10:47 AM
sodak86
May 24, 2015 03:54 PM
Fatdog2
Mar 31, 2015 06:50 AM
kandied91z
Jan 23, 2015 11:14 AM
stevil
N2O Tech
Jan 4, 2003 10:29 AM
