9.8 @ 149
Old Oct 25, 2004 | 07:36 AM
  #16
RealQuick's Avatar
Re: 9.8 @ 149
Thats fast!
Old Oct 25, 2004 | 12:09 PM
  #17
MEAN LT1's Avatar
Re: 9.8 @ 149
Good run man, love the mph
Old Oct 26, 2004 | 10:32 PM
  #18
Highlander's Avatar
Re: 9.8 @ 149
You see.. now i am happy with your MPH!!!!! 143mph is a bit shy for a 850rwhp car...
I bet with better "track tuning" you will get past the 150-151 which is what your car SHOULD AND WILL!!!! trap.
Dude congrats
Old Oct 26, 2004 | 10:43 PM
  #19
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Re: 9.8 @ 149
Thanks everyone, I appreciate it.
sleeperz28- The trans was done by G-force. It has their 1st-4th gearset, 4340 30 spline mainshaft, and triple cone conversion. So far it's been working great, clicks right into gear without lifting off the gas.
http://www.g-forcetransmissions.com/tran_gt-56.asp
We are a dealer for G-force, so let me know if it is something you are interested in.
As far as timing, I am running 19 degrees at peak torque and 21 degrees at peak horsepower. It lost power with more timing on the dyno.
The Highlander- Thanks, and fwiw this run was made at 24lbs of boost which I would estimate to be around 930 rwhp. I may put some 27in tall tires on it and try to break 150 as I'm out of RPM with the 26's.
Old Oct 26, 2004 | 10:49 PM
  #20
Highlander's Avatar
Re: 9.8 @ 149
How much boost did you see before????
i will be using 28x10.5 on back.. i expect around 9.8 BUT at 143mph or so... not that wicked MPH i could crank up the boost though... the ysi should support to almost 950rwhp.
intimd8... how much $ to beefen up that m6? i might need to do it...
Old Oct 27, 2004 | 10:40 PM
  #21
Sevendustx1's Avatar
Re: 9.8 @ 149
Great times. Was wondering What kinda rings you using to withstand 24psi.
Old Oct 27, 2004 | 11:37 PM
  #22
Z97LT1's Avatar
Re: 9.8 @ 149
Jim, how many street miles do you drive that thing? Still on the same old shortblock that supported the S-trim a while back?
Old Oct 28, 2004 | 05:53 AM
  #23
Highlander's Avatar
Re: 9.8 @ 149
I think he is.. eagle crank, eagle rods, je pistons... pretty much what i had last time.. although i changed to a callies racemaster crank
Old Oct 28, 2004 | 11:46 AM
  #24
n2oblkz
Guest
Posts: n/a
Re: 9.8 @ 149
Posted by:Sevendustx1
http://ls1speed.com/jim.cfm
Above is the link to all of his mods. I am following what he has done for my buildup. I am going to use the same pistons and the same rings. He is using the Speedpro Hellfire.
Z284ever
14
Oct 11, 2006 10:56 PM
97Z-M6
Feb 10, 2005 02:26 AM
N2OpwrdTA
May 25, 2003 09:50 PM
