8-Rib: 10% belt slip rule of thumb??
Old Feb 28, 2007 | 05:40 PM
boosted-lt1's Avatar
Hello,
Anyone have any more information on a rule of thumb for belt slippage, particularly with an 8-rib setup (6.66/2.95)?
I was just going through some of the impeller speed calc's again and I am contemplating pullying for ~10% above what I am actually shooting for.
Thoughts?
-Scott.
Old Feb 28, 2007 | 05:57 PM
rskrause's Avatar
Moderator
The belt should not slip if it's adequately sized for the amount of power transmitted and installed correctly. IOW, do not add 10% for slippage.
Rich
Old Feb 28, 2007 | 06:21 PM
Thanks Rich,
I see your point, but how do you quantify that? Theoretically a ribbed belt should not slip and this is how the rpm formulas are setup. Should we assume XX% efficiency in driving a blower with a ribbed belt?
Belt slip seems to be a legitimate concern with these types of setups. I wonder if anyone has gone from ribbed to cogged at the same ratio with any findings.
Furthermore, I wonder that if I mark the blower pulley and belt with paint would I see the two points offset after driving?....at full throttle?
Thanks,
-Scott.
Old Feb 28, 2007 | 08:37 PM
rskrause's Avatar
Moderator
If the belt slips, it's most likely to do so when you let off the gas after running at max boost. This is good, to a point, as it helps prevent surge. If you do as you propose, it is a mistake and you will be driving the blower 10% faster than you intended.
Old Mar 3, 2007 | 07:49 PM
whonxt?'s Avatar
Rich
I disagree, the belt will slip some with the ATI setup. My suggestion to eliminate most belt slip without blowing your budget is to have the inside ribs sandblasted from both the blower and the crank pulley for better traction. Also, have a machine shop mill 1/16 off each end of the pulley grooves to allow the belt to sit deeper in the pulley's. This has gained 1-2 #'s more boost on many cars at my shop. MY car turns 7k rpm's on a 3.4 pulley, and I think that is a good indication of proof my method works. Also, I would give your blower at least a 5% cushion from the blower max rpm just to be safe. It's an expensive part and the extra risk does not produce much better results. My .02 though.
Old Mar 3, 2007 | 10:07 PM
CALL911's Avatar
I've got an 8 rib setup from ATI on my D1SC with the smallest pulley combo available for it. Mine doesn't slip at all, but then again I have a SDCE tensioner on it as well.
Old Mar 3, 2007 | 10:25 PM
whonxt?'s Avatar
Your tensioner is great. I believe you, but most stock ATI setup's slip some at the crank pulley. I just think the small things can really make a difference!!!
IndyZman
Oct 22, 2015 02:17 PM
95blkss
Sep 22, 2015 03:18 PM
Sep 18, 2015 03:46 PM
USN06
Sep 7, 2015 03:30 PM
rideordie
Sep 7, 2015 08:22 AM
