5psi, fmic, what upgrades
Old Aug 5, 2005 | 08:19 PM
steves97z28's Avatar
i was gonna do the fuel pump but i heard its not really needed. what should i upgrade for 5psi, and fmic. should i do injecters and if so what size.
Old Aug 6, 2005 | 01:56 AM
breakmyfootoff's Avatar
Re: 5psi, fmic, what upgrades
I would recommend a larger fuel pump for any FI application, even 5 psi. As far as injectors, with 5 psi and an FMU stock injectors would be OK, if you're going to tune for the supercharger without an FMU I'd go with 36lb'ers and tuning.
Old Aug 6, 2005 | 08:15 AM
NYSS Guy's Avatar
Injector size is going to depend on what your long term goals are. If you are going to run more than 5 psi, you may want to get the larger injectors from the beginning. If you are going to run 8 psi or more, I would suggest getting 60 #'s. And definitelt get the fuel pump no matter what. You don't want to skimp on fuel in an FI setup.
13qtr
Oct 28, 2016 08:11 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
97SSdude
Aug 21, 2015 09:36 AM
