4" Dryer Hose - Where to buy?
Hello,
I thought I would start here to see if anyone had any suggestions on where to get some 4" dryer hose style tubing for compressor inlet plumbing.
Thanks!
-Scott.
Thanks!
-Scott.
Scott, you may be able to find a foam filter from this company (used by a few boosted guys on ls1tech):
http://uniflow.com.au/index.html?lmd=39654.412488
Jon
Jon
Jon,
Good suggestion. Growing up on dirtbikes I can't believe I didn't think of that (foam+oil filter). I did get this response from Uniflow:
Hi Scott,
Thanks for your email. We have no filter that will fit in that space plus it is
not recommended that you clamp a filter directly to the front of a turbo. You would be best to try and pipe a filter away from the turbo.
No worries, I'll come up with something. The screen is working but probally not the best solution for the opti venting.
-Scott.
Hi Scott,
-Scott.
