4/7 cam swap
Old Feb 13, 2005 | 05:16 PM
J'S Z's Avatar
4/7 cam swap
Have anyone ever tried one of these cams with blower cars?I know Lunati is putting one out on the market I think Comp as well.Suppose to be worth a little more hp.I did a search and did find some info in the advanced forum.I was hoping some over here had already tried it.Any comments.Thanks fellas
Old Feb 13, 2005 | 08:12 PM
biggtime's Avatar
Re: 4/7 cam swap
I run one in my *street* car. My 355/afr regular 210's/D-1 16lbs/ makes 650+ to the wheels with it. This one is a custom grind from comp. I have been running them for 10 years in my race car (lunati custom) so it is pretty common for me. If you are running a TPI, HSR or a LT-1 it is a real good addition.
Old Feb 14, 2005 | 10:44 AM
mn_vette's Avatar
Re: 4/7 cam swap
what's a 4/7 cam?
Old Feb 14, 2005 | 10:47 AM
biggtime's Avatar
Re: 4/7 cam swap
Originally Posted by mn_vette
what's a 4/7 cam?
Changes the firing order from 1-8-4-3-6-5-7-2 to 1-8-7-3-6-5-4-2
Old Feb 14, 2005 | 11:31 AM
NC-LT1's Avatar
Re: 4/7 cam swap
I have been wondering about this as ell for some time for one of our vettes running an LT4, does it change any other characteristics of the motor for those of you who have done it..? thanks!
Chris
Old Feb 14, 2005 | 11:35 AM
dhirocz's Avatar
Re: 4/7 cam swap
I've considered doing this on my next motor. Wasn't sure how it would act with EFI, though I doubt the computer would notice by swapping the plug wires and cams. Anybody know how much just the swap itself is worth?
Old Feb 14, 2005 | 11:36 AM
biggtime's Avatar
Re: 4/7 cam swap
Chris
I don't know about the stock ECM but since you are sequential you need to change when the injectors fire also.
Old Feb 14, 2005 | 12:15 PM
dhirocz's Avatar
Re: 4/7 cam swap
true...
Old Feb 14, 2005 | 03:21 PM
mn_vette's Avatar
Re: 4/7 cam swap
What would be the point of doing this???
Old Feb 14, 2005 | 05:55 PM
J'S Z's Avatar
Re: 4/7 cam swap
Hey Biggtime thanks for the reply.As a matter of fact I was thinking of going with a HSR.Doug Flynn over at Holley says they will be coming out with an intake that matches the1206 heads just digging up ones who have done this already.For others who would like more info do a search in the advanced tech forum.Thanks fellas
Old Feb 14, 2005 | 07:07 PM
wantafastz28's Avatar
Re: 4/7 cam swap
More power.
These have made a noticeable difference.
Old Feb 14, 2005 | 09:24 PM
rskrause's Avatar
Moderator
Re: 4/7 cam swap
I am ordering a new cam for my race car and am going to do a 4/7 swap. Funny GM never figured this out. Anyone know who did?
Rich
Old Feb 14, 2005 | 09:41 PM
biggtime's Avatar
Re: 4/7 cam swap
Rich
I learned it from Radar and Jenkins back in the early 90's. I know Jesel new about it also.
If you are using a factory style retention plate make sure you tell them when ordering as it takes a special core.
Old Feb 14, 2005 | 09:51 PM
rskrause's Avatar
Moderator
Re: 4/7 cam swap
Thanks foir the info. It's a BB chevy and I believe Comp (where I get my cams) does have a core for it.
Rich
Old Feb 14, 2005 | 09:56 PM
biggtime's Avatar
Re: 4/7 cam swap
Rich
I get most of mine from comp also. When i ordered my smallblock one i forgot i was using a roller block and just gave them the core numbers. Lucky for me they called back. You not putting a big block in your camaro are you?
