4.25" P1SC pulley #
Old Feb 6, 2007 | 12:51 PM
VK's Avatar
VK
4.25" P1SC pulley #
Well, i got my blower on and took it out for a quick run. I saw 10-11psi @ about 6K rpms.. i was told this pulley was a 8psi pulley for a stock lt1..
Old Feb 6, 2007 | 01:36 PM
Ponyhntr's Avatar
That pulley did make 8 psi at 5700 rpm on the stock motor that it was on. I'm 100% positive with that. What type of air inlet do you have on there? With revving it to 6000, and with no filter on it (maybe?), I could see it making 10 psi easily.
Old Feb 6, 2007 | 02:00 PM
VK's Avatar
VK
Thanks for the reply man. Didn't mean to imply you were wrong, just looking for ideas what i'm doing to run this much boost so i can stop it .. if it keeps happening the motor is going to blow alot sooner then i want.
Old Feb 6, 2007 | 02:13 PM
Ponyhntr's Avatar
Yeah, I know. I know it's probably extremely cold up there where you're at (it is here!), so once it gets warmer this spring, that boost level will come down a bit. It's not uncommon to see a pound or 2 more boost in weather conditions like this, because of the colder, dense air.
Old Feb 6, 2007 | 02:31 PM
VK's Avatar
VK
Alright, guess i'll just have to wait and see then. Thanks for putting my mind at ease.
Old Feb 7, 2007 | 11:08 PM
posenheimer's Avatar
same blower and pulley you have... I only make 7 pounds of boost 7k ft elevation, perhaps that is the difference
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
