4.17 Vs 4.25 puley D1SC
Old Jun 9, 2005 | 08:41 PM
hellostop's Avatar
If I had my 94z dyno tuned with a 4.17 in puley and then changed to a 4.25 to reduce boost. Will I now be running a little rich under less boost? Do I need a retune?
Stock engine, headers, 3" cat back. 42# injectors. D1SC w/ twin i/c's.
Old Jun 9, 2005 | 08:53 PM
97WS6SCharged's Avatar
Re: 4.17 Vs 4.25 puley D1SC
A little rich on a stock engine is usually a good thing.
Old Jun 10, 2005 | 10:05 AM
Kredz28's Avatar
yea no kidding! Given the size difference in the pullies it wouldnt decrease boost too much, but when it comes to having FI on the stock cast pistons, its usually best to play on the rich side. Ive got mine at 12:1 right now to be safe.
Old Jun 10, 2005 | 08:34 PM
hellostop's Avatar
The tuner set mine a/f to 10.5, and that was with the smaller pulley.
Any downside to too rich? Its during fuel inrichment mode only, isnt it? System s/b closed loop when your foots not in it.
Old Jun 11, 2005 | 06:41 PM
Kredz28's Avatar
The A/F ratio you have sounds really rich...How much boost are you running? Do you see any type of bog at lower rpms? If your running quite a bit of boost, im sure that it leans out in boost. I see 7 psi right now, and my tuner had mine set at 10.5 which bogged like crazy throughout the revband. For the most part, its best to play on the rich side with FI to keep cyl temps down and avoid detonation (especially on cast pistons).
Old Jun 11, 2005 | 09:00 PM
hellostop's Avatar
Interesting you should ask, I do have a stumble, bog, off idle...
too rich?
Old Jun 11, 2005 | 09:02 PM
Possibly. Do you have any datamaster logs?
Old Jun 11, 2005 | 09:03 PM
hellostop's Avatar
running around 7 boost.
Old Jun 12, 2005 | 11:21 AM
Kredz28's Avatar
too rich?
I would retune. The thing to keep in mind is if you lean it out a little to remove the bogging, it essentially can lean it out too much at righ rpm, which may lead to detonation. The only way to do it is to get on a dyno, get a wideband on it and watch you a/f ratio throughout the revband.
Old Jun 12, 2005 | 10:15 PM
hellostop's Avatar
I dont have any logs.
I probably paid too much for original tune, and car has never run right. I'm hesitant to go back, but hate to pay someone else too. Even if i I bought a wideband, I quess I have have to buy some software to lean out. tough choices.
Old Jun 12, 2005 | 10:19 PM
hellostop's Avatar
Kredz28, how long have you had a D1sc on stock pistons @ 7 #'s??
bunker
Jan 30, 2016 08:09 PM
bunker
Aug 21, 2015 10:21 AM
95blkss
Jul 13, 2015 01:28 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
Mike383LT1
Jan 20, 2004 11:39 AM
