396 T-trim boost
Old Jun 26, 2003 | 02:15 PM
RonnieW's Avatar
396 T-trim boost
Anyone with something similar to mine that can tell about how much boost I will get once I put the SC'er on?
396 LT-1, 9.2:1 cr, AFR 227 heads, solid roller. Not inter/aftercooler, will be using alky/water. I am in the process of tuning (FAST) the engine without the SC right now.
Old Jun 26, 2003 | 04:03 PM
IDOXLR8's Avatar
Hey I am not sure how far Melbourne, FL is to you but I would highly recommend you give Cal Hartline a call. He is one of the best FAST tuners in the country. Tell him Arthur sent you. Check out his website: www.hartlineperformance.com.
Your boost level will depend on what blower pulley you are running and also how high you plan on spinning your car.
Old Jun 27, 2003 | 06:42 AM
MEAN LT1's Avatar
Re: 396 T-trim boost
Cool, It sounds like your car is turning out pretty good. What size pulley do you have for the crank and blower pullies?. it all depends, with your setup if say you had it pullied for 15psi I would think you would only see about 11-12 due to the increase in cubic inches and the better flowing heads. What alky injection system did you get?.
Old Jun 27, 2003 | 08:38 AM
RonnieW's Avatar
I am pulley'd to max out the impeller speed at around 6600 rpms right now (7.6"/3.125", 8 rib). I may have to change to get it up to around 7000. I will know better once I see where my peak HP is NA.
I am using or will be using the SMC kit.
Old Jun 27, 2003 | 01:18 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
most of the succesful cars I know overspin S/Ttrims a little.. so you may be closer than you think
Old Jun 27, 2003 | 02:27 PM
RonnieW's Avatar
I wonder how much overspin it will take before it becomes detrimental. Have the guys you know Jordon taken them up much above max. The max for the T-trim is listed as 55000 with 52000 being the suposed optimum.
Old Jun 28, 2003 | 01:53 AM
LJ stevens on here spun his S-trim hard. 7"/2.65".
no failures, car ran 9.9 @ 139!
Old Feb 29, 2004 | 10:23 PM
Highlander's Avatar
Where did you get the 7.6" pulley?
Old Mar 1, 2004 | 07:50 AM
RonnieW's Avatar
The pulley was part of the ASP package for my 8 rib set up. The pulley is actually part of the balancer on the Vettes.
Old Mar 1, 2004 | 07:51 AM
Highlander's Avatar
OIC... so its not for an f-body
I will ask ASP to see if they have it...
Thx
RUENUF
Mar 13, 2016 03:37 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
96SilverRam
Sep 7, 2015 10:51 PM
Henson071
Aug 4, 2015 09:32 AM
