3 wire, 2 bar MAP wiring
Old Jun 8, 2004 | 07:22 PM
96 WS6's Avatar
I am using a 2 bar MAP for my alky injection. I know the green wire is the output voltage 0-5v. The other two wires are power and ground correct? Do I just hook up to a 12v positive and a ground? Simple answer, thanks!
Old Jun 8, 2004 | 08:09 PM
Lonnie Pavtis's Avatar
You need 5VDC to power the sensor. You can reference it from the stock PCM or buy a power supply fromAlkycontrol
Old Jun 9, 2004 | 03:42 AM
96 WS6's Avatar
So it has a 5 vdc reference signal and the black wire is ground then correct?
To get 5 vdc I can tap the power going to the stock MAP sensor correct?
Old Jun 9, 2004 | 09:52 AM
RealQuick's Avatar
Omar, I am using the kit from you and would like to know as well. Is there a reason we cant tap into our 1 bar stock map?
Old Jun 9, 2004 | 05:38 PM
94Z286SPEED's Avatar
just piggyback into the stock sensor center is used for reference signal that's it. you cant use the factory sensor because it will not see pressure when it hits 0 vacumm the sensor is maxed as the 2 bar sees up to approx 15lbs before it is maxed.
ldtantlinger92
Jan 19, 2015 01:26 PM
Ryabut98
Sep 3, 2002 11:45 PM
$hawn
Aug 3, 2002 04:59 AM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
