224/236 low lift on a 112 vs 114
Old Aug 13, 2005 | 03:04 PM
onlyone07's Avatar
How much of a difference do any of you think I might see with this cam ground on a 112 instead of a 114? The heads are going to be stock unless I can scrounge up some money to open the bowls up a little bit for that extra drop in compression. The blower is a P600B pullied for 12psi.
The topic seems kinda short and sweet but it's been on my mind for quite some time. I paid $100 for the cam from a friend so I figured "What the hell?".
Old Aug 13, 2005 | 04:26 PM
Bryan 94 Z28's Avatar
Re: 224/236 low lift on a 112 vs 114
Mine did a lot better on a 114 LS rather than a 112 LS. But then again, I was going from the CC306 to the cam you're going with (Comp Cams XE 224/236) with the 114 LS.
With the blower, I really don't think you need to have that narrow of a LS. The compressed intake air will take care of itself in getting into the cylinders....
Old Aug 15, 2005 | 01:39 AM
SS Mark's Avatar
12 psi on stock bottom end/compression? LT1? Not gonna be a good idea As far as the cam, the extra overlap will bleed off more boost than with the 114 lsa.
-Mark
Old Aug 15, 2005 | 02:08 AM
onlyone07's Avatar
It's gonna be a far from stock motor. Eagle 4340 crank/Scat 4340 h-beams/Wiseco dished pistons/all supporting mods.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Noct
Jul 14, 2015 01:18 AM
birdblack
Jul 8, 2015 07:23 AM
