2 bar map tunes on LT1.
Old Mar 30, 2005 | 01:07 PM
Roadie's Avatar
I know a few of you attempted tuning with 2 bar map sensors a while back. Just checking in to see how they're doing, now that they've been on the tune a little while.
I'm getting ready to attempt this and any experiences/tips/tricks you learned along the way would be helpful and appreciated.
Old Mar 30, 2005 | 06:49 PM
93redz's Avatar
Re: 2 bar map tunes on LT1.
i had alvin at pcmforless do mine . i have not put many miles on yet but it seems to be working just fine.
Old Mar 31, 2005 | 04:16 AM
1982z28with18s's Avatar
I heard alvin did someones car, what exactly is your setup? Details please.
Old Mar 31, 2005 | 06:29 AM
93redz's Avatar
i have a 69 camaro with a 93 lt1 in it.it has 10.8 to 1 compression with afr cylinder heads and a hot cam.complete forged bottom end and 42lb fuel injectors and no fmu just a 2 bar map sensor.i have long tube headers and a turbo 350 trans.the only problem im having is when i pull it in gear it wants to stall sometimes but i think he has it a little rich to be safer thats what i asked for though.i ran 12.40s on the engine only im waiting to go to the track with the blower on to see how it runs.i have a ati procharger non intercooled makiing 5 lbs of boost.any other qestions feel free to email me.ps alvin is a great guy to deal with and realy knows what hes doing.
Old Mar 31, 2005 | 09:20 AM
Roadie's Avatar
thanks for the info. Anyone with 94-95 PCMs?
Old Mar 31, 2005 | 05:45 PM
SMOKNZ's Avatar
He made it rich at idle to be safe? Didn't think going lean at idle would hurt any.
Old Mar 31, 2005 | 07:49 PM
93redz's Avatar
he made it rich over all. you are absolutely correct that at idle it wont hurt a thing thats not what i meant .i need a dyno tune to get it just right .This was just a begining tune.
Old Mar 31, 2005 | 09:16 PM
Did he do it via mail order?
Old Apr 1, 2005 | 06:30 PM
93redz's Avatar
yes it was a mail order tune
Old Apr 6, 2005 | 09:07 AM
carnutz's Avatar
Hmmm so what exactly do I need to do other than rescale the map table? Is there other issues when it goes through its self check/calibration deal at key on? I assume the ECM would get slightly skewed info as to altitude, when it sees the different value than expected? Help me out Im not quite grasping the inital key on deal. Maybe it doesnt matter.
Old Apr 6, 2005 | 12:49 PM
Roadie's Avatar
I'm not entirely sure... I put together a nice initial tune, but haven't put it into the car yet (someone is borrowing my tuning laptop for the next month).
You do lose some granularity since the table is the same size and you're squeezing 2 atmospheres into it. Here's what I scaled down:
Main Spark Advance vs. RPM vs. MAP
Extended Spark Advance vs. RPM vs. MAP
Spark Correction Vs. MAP vs. coolant temp
Max Spark retard vs. MAP
open loop afr vs. map
egr correction vs. vaccum (EGR deleted though)
low octane knock retard multiplier vs. map
the VE tables
Then you simply (haha) have to come up with the rest of the table.
I'm fairly certain the tune will start the car, but I'm also fairly certain it'll be off quite a bit and will need a lot of tweaking.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
HarleyZ28
Oct 5, 2015 06:23 AM
thenewkid
Apr 12, 2015 07:42 PM
