15psi D-1 pulley
Old 04-07-2005, 12:35 AM
ProchargedLT1's Avatar
15psi D-1 pulley
What does ATI consider a 15psi pulley?
ProchargedLT1 is offline
Old 04-07-2005, 10:07 AM
KS91Z28's Avatar
Re: 15psi D-1 pulley
The same pulley may work for several different cars, so they don't call a particular pulleya "15 psi pulley". They go by the diameter of the pulley. For instance, a 3.4 pulley may make 15 psi on your car, but the same pulley may make 10 psi on a Mustang. It's all a matter of how restrictive your motor is.
KS91Z28 is offline
Old 04-07-2005, 10:25 AM
I'm talking about for an LT1 car. What size pulley would it be if you ordered a "15lb" pulley with your kit?
I know different motors will see different boost readings with the same pulley. The reason i ask is because i have a 3.4" pulley right now and i think its going to put out way more boost than i want. I'm running Stock heads with stock valves and mild porting. I'm sure i would see a large # on the guage due to my heads not flowing the best.
L8ter
Old 04-07-2005, 12:14 PM
KS91Z28's Avatar
Is your blower actually a D1 or is it a D1SC? If it's a D1SC they would probably send you a 3.4 to make 15 psi. If it's a D1, they would prbably send you a 3.7 or something like that.
KS91Z28 is offline
Old 04-07-2005, 12:50 PM
I have a D-1.
Thanks for the replies!
Old 04-07-2005, 01:18 PM
KS91Z28's Avatar
No problem. Sorry I couldn't narrow it down any more.
KS91Z28 is offline
AviatorDave
12-19-2016 06:35 PM
RUENUF
03-13-2016 03:39 PM
RUENUF
03-13-2016 03:37 PM
sleeperZ96BT
09-09-2015 08:28 AM
Slayer
08-17-2015 03:55 PM
Quick Reply: 15psi D-1 pulley
