Y pipe question
Old Apr 4, 2011 | 10:28 PM
jloshotz's Avatar
Y pipe question
General question without getting too involved in the particulars....Could having a y-pipe (shorty header style) in contact with the oil pan cause a false knock condition, causing a timing pull that may be mistaken for vibration above 2500 rpm? I don't have any live data at that rpm....just a thought...anyone have experience with this?
Old Apr 6, 2011 | 07:09 AM
USAFretired's Avatar
Re: Y pipe question
I wouldn't think so. But it could cause a hole in your oil pan and then a serious knock to follow
Old Apr 7, 2011 | 04:10 PM
jloshotz's Avatar
Re: Y pipe question
It's barely touching, and seeing how it is smooth....moves with the engine...can't see a rub through happening. Thanks for the input though.
Old May 2, 2011 | 09:13 PM
Nickw059's Avatar
Re: Y pipe question
It will eventually start rubbing through
Old May 2, 2011 | 10:06 PM
Re: Y pipe question
The Y-pipe is firmly bolted to the manifold (or headers). The manifolds (or headers) are firmly bolted to the heads. The only movement of the Y-pipe relative to the oil pan will be a tiny amount of thermal expansion as the Y-pipe heats up.
Yes, if the exhaust is in contact with the pan, the exhaust noise will be transmitted to the pan, and thats bolted to the block, and the the knock sensor is in the block immediately above the oil pan.
You will also see the oil heating up and thinning out, which is yet another problem.
Old May 30, 2011 | 08:06 AM
jloshotz's Avatar
Re: Y pipe question
Thanks Fred, hadn't seen this response. Still have to get under there to correct this issue (put about 10 miles a month on the car lately) thanks for your input, never considered the oil thinning out angle!
Old May 30, 2011 | 09:29 AM
Re: Y pipe question
I had a collector leak blowing on the oil filter with my old JBA shorties, and the first sign was the oil pressure dropping.
Old May 30, 2011 | 09:44 AM
jloshotz's Avatar
Re: Y pipe question
That's one of the main things I love about this forum, if there is even a remote "real world" possibility, someone has most likely been there done that. I might actually mess with the car today, day off and all. Enjoy your Memorial day Fred
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
onefastgta
Mar 19, 2015 10:10 AM
MadMav
Feb 6, 2015 11:02 PM
alphaauto
Parts Wanted
Jan 23, 2015 06:17 PM
thenewkid
Nov 18, 2014 12:57 PM
