Will an Electric Cut-Out Fit?
Old Apr 12, 2008 | 04:05 AM
Counted Out's Avatar
The cutout is located infront of the Catalytic converter (both are located near the front of the passengers door, but under the car of course). Someone said they heard E-Cutouts won't fit unless they are put after the Cat behind the rear axle.
That didn't make any sense to me, but he seemed pretty sure. Will I be able to fit an E-Cutout with my current location?
Old Apr 14, 2008 | 12:19 AM
mrr23's Avatar
electric cutouts fit wherever the cutout is located at and if you have clearance. has nothing to do with cats.
Old Apr 14, 2008 | 04:00 AM
That's what I mean. I heard it was a clearance issue if they are placed before the cats.
Old Jun 28, 2009 | 09:29 AM
JP95ZM6's Avatar
It looks like they would be the low spot in the system there even if they do fit, although I'm pretty sure the would not fit there. Bigger flange to hit body and ground. That looks impossibly low to the ground already. Only E cutouts I've seen reasonably packaged are in the cavity on the left of the car, under the rear seat area. That's where mine is going - single in I pipe.
RUENUF
Mar 13, 2016 03:39 PM
4586
Apr 24, 2015 01:03 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
