Summit x-pipe kit w/ Hooker LT's.
Old Dec 11, 2006 | 07:48 AM
Javier97Z28's Avatar
Moderator
Anyone get these two to work together for a DIY job? The Hooker LT's practically hug the floorboard and my current Y-pipe has a small drop down mandrel bend that gives additional clearance downward before the Y.
I'm thinking a straight shot out of the Hooker will run into stuff, but I have to look again to make sure. Even w/ my Poly motor mounts in it doesn't look like there's enough room....
Anyone try this combo yet?
Old Dec 11, 2006 | 12:39 PM
teke184's Avatar
i'm running 3" duals using the summit Xpipe on my LS1.
i've also got the poly motor mounts and my clearances are less than 1/2" and never have hit.
what kind of mufflers are you planning on running?? because in all honesty...if i could do it again i would build a TD setup out of my old Ypipe. just cut the junction off before the merge and run 2 pipes parallel down the passenger side of the torque arm. you can probably run 2 bullets, staggered so that they don't touch and dump both before the axle with no major lose of clearance. magnaflow even makes an X pipe junction..with parallel inlet/outlets (unlike most 45* inlet/outlet Xpipes) to make the setup even easier.
that's what i'm planning on running someday. but i plan to run the pipes over the axle and put the mufflers out back.
do a search for Gripenfelter's TD post...it has plenty of pics of his and other setups.
Javi Fierros
Exhaust System
10
Apr 20, 2017 12:46 PM
KamikaZ28
May 28, 2015 12:45 AM
QuickSilver02
Apr 7, 2015 11:12 AM
jasonduaine
Apr 1, 2015 08:09 PM
Queens94z28
Dec 20, 2014 09:11 PM
