Stage 8 header bolts
Old Dec 21, 2006 | 05:18 PM
SROACH's Avatar
I just purchased a set of Stage 8 header bolts for my Jet Hot LT but I am unsure if they are the right type for a LT1. On the box it says for a SB Ford size(16)3/8-16x3/4. The sales guy says that is the right size and that it doesn`t matter if it says SB Ford on the box. What is the right size Stage 8 header bolt or was the sales guy right???? Please help.
Old Dec 21, 2006 | 07:37 PM
MarcR94v6's Avatar
I got Stage 8 bolts for the 3.4 and they said "for 2.8L". I called the stage 8 hotline (is that what you mean by salesguy?) and he said they will fit. I already knew of the relation of the 2.8 to the 3.4, but I was just making sure. If a Stage 8 employee tells you they will fit, then they probably fit. I don't think it's that unlikely that a few peices here from GM and Ford are the same.
Old Dec 22, 2006 | 01:52 PM
2000GTP's Avatar
Those should be the right ones, but personally I would have opted for the 1" long bolts instead of the 3/4"
Old Dec 22, 2006 | 10:15 PM
byrons1502's Avatar
they will work. the bolts are maybe a little shorter than i think i use. 1" sounds right
Old Dec 29, 2006 | 10:47 AM
Bud M's Avatar
The difference is that Fords use 16 bolts and Chevys use 12 so you will have some left over. I used 3/4 bolts on my Hookers, no problems.
Old Dec 29, 2006 | 02:41 PM
BUBBA's Avatar
Depending on the thickness of you're flanges, but I'd opt for 1" to make sure.
For that matter, I'd consider going with SS ARP---since I beleve it would be a pia to install and remove the locks on the Stage 8s. JMHO
Old Dec 29, 2006 | 03:25 PM
95LT1conv's Avatar
stage 8's anre a PITA. just when you think you have them tight, you have to back them off to get the lock on. i gave mine away and got SS ARP 1" and used a set of Mr.Gasket header lock washers in place of the ones that came with the ARP
Old Dec 29, 2006 | 04:24 PM
2000GTP's Avatar
Yep, installing Stage 8s on my friends LS1 became a two man job. Who would have thought installing bolts would be so difficult.
Old Jan 6, 2007 | 09:56 AM
PoorMan's Avatar
glad i got the 12 pt ones. I still had to grind a wrench down to tighten one of them.
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
importkiller94
Jan 17, 2015 09:03 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
