shorties to long tubes
Old Oct 3, 2008 | 06:56 PM
chevyrules85's Avatar
right now i have hooker shorties with a y pipe into a flow master cat back, no cat.... what im wondering is if i change to pacesetter long tubes with ORY into my flow master cat back, how much will my sound change? and how exactly would the sound change?
Old Oct 3, 2008 | 09:53 PM
grossesexy's Avatar
Basically the sound of your catback is going to be amplified even further, it's going to get louder.
Old Oct 4, 2008 | 12:25 PM
so it wont change the tone of the sound any? just make it louder?
Old Oct 4, 2008 | 05:48 PM
Zaknafein's Avatar
If you're not changing the exhaust system, ie; routing, mufflers, etc., then the sound isn't going to change much either.
Old Oct 9, 2008 | 11:41 AM
Andrew@MarylandSpeed's Avatar
It WILL change the tone some just swapping out the headers. The exhaust flow is going to totally change due to the design difference, which will result in an increase in volume and change in tone. Won't be as noticeable at idle as it will be under throttle, but you will definitely hear a difference.
Old Oct 9, 2008 | 10:35 PM
6Speed's Avatar
I changed from mac shorties to hooker longtubes. The sound is a little smoother on teh outside, but nothing that anyone other than you would notice. I don't think it got any louder...maybe a tad less deep though. On the inside you can hear the biggest difference. It's almost like you can hear the sound of the air passing through the tubes under your feet. It's strange, can't really explain it...sorta a hollow smooth sound...
MDZ28
Exhaust System
Jun 2, 2015 09:48 PM
drptop70ss
May 4, 2015 08:22 PM
MDZ28
Exhaust System
Apr 29, 2015 07:44 PM
4586
Mar 18, 2015 06:31 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
