rust on the pacesetter coated after 8 months
Old Jan 26, 2008 | 05:33 PM
Critter's Avatar
any way to slow it down?
Old Jan 26, 2008 | 06:47 PM
2000GTP's Avatar
You could maybe try getting under there with some Scotch brite or brillo pads or something. I gave up long ago. The coating on my Pacesetters started to rust well before a years time.
Old Jan 26, 2008 | 10:26 PM
sn8ke eatr's Avatar
i got bubbles right around the flange.. this is after about 6 months and maybe 1000 miles
next time around im spending the dough on kooks.
Old Jan 27, 2008 | 06:57 AM
Greed4Speed's Avatar
The reason being is that the coating is a THERMAL coating, not a rust preventative.
Old Jan 28, 2008 | 09:06 PM
mrmint69's Avatar
I have never checked for rust so they must be fine. Looking would do no good at this point. I have the dry air crystals in my garage so i hope this helps some. I know my factory ones had little rust so the moisture problem must be not so big here. I see some on Ebay that looked like they were under water for years.
Old Jan 29, 2008 | 02:58 PM
MeanGreen97Z's Avatar
Get under there with high temp rust spray paint.... hit them up every few weeks. It's what I do on mine...
Old Feb 1, 2008 | 01:30 AM
za355tx's Avatar
Jet hot says to polish them once or twice a year with a good wheel polish (mother's aluminum wheel polish) and to wash them with soap and water every so often. That came straight from jet hot when I had mine recoated under warranty and told them they rusted after about 5k miles. They said that should help a bunch. Call them and ask them they'll tell you the same.
Old Feb 1, 2008 | 07:12 AM
2000GTP's Avatar
Seems like alot of work. It is almost impossible to get to certain portions of the header also with the cramped up engine bay. I don't Pacesetter offers a lifetime warranty on their coating though.
Old Feb 1, 2008 | 05:49 PM
leadfoot94's Avatar
My Jet-hot LT's had a ton of rust. I never even drove the car in the rain.
Old Feb 1, 2008 | 06:14 PM
2000GTP's Avatar
My car has never seen rain or snow either. On top of that, it sees very limited miles altogether. Mine started rusting pretty bad in less then a years time.
Old Feb 1, 2008 | 11:43 PM
reamo04's Avatar
my car saw a whole winter, and tons of rains....headers only had a surface blemish that wiped right off with a dry rag...no rust after a year what so ever
Old Feb 20, 2008 | 11:01 AM
sn8ke eatr's Avatar
exactly what he said..
Old Feb 20, 2008 | 01:38 PM
Critter's Avatar
should i sand off the old rust or just spray over it with some rust preventor type paint?
Old Feb 20, 2008 | 02:45 PM
2000GTP's Avatar
Run some sandpaper or a brillo pad over it.
Scorch1
Jun 30, 2015 11:24 PM
KamikaZ28
May 28, 2015 12:45 AM
May 1, 2015 01:14 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
LT14LIFE
Feb 9, 2015 09:35 PM
