rattling noise coming from cat converter
Old Jan 11, 2007 | 01:05 AM
ZX636RIDER03's Avatar
Angry rattling noise coming from cat converter
ive got a 97 lt1 dual cats passenger side cat is rattling like crazy at idle and a little when driving, i checked the brackets and it is not loose, i have a stethescope and it sounds like it has a rock bouncing around in there. is there something in the cat that could break loose and do this? i dont know how anything could have made it through the valve train without breaking something and the engine runs and sounds normal.
Old Jan 11, 2007 | 01:11 AM
Angelis83LT's Avatar
just a quick one. but are you sure it is not the heat sheild on cat. or on the top of the cat rattleing on it? if it is rattleing on the top of it it will sound like something beating around inside of it...
Old Jan 11, 2007 | 01:49 AM
dfa_crunch's Avatar
my gf's car had the same noise, it was the heat-shield
Old Jan 11, 2007 | 02:15 AM
doug1105's Avatar
If it's not a bracket or heat shield bouncing, it's probably part of the catalyst honeycomb broke loose inside there.
I had it happen and it sounded like rocks bouncing in a coffee can.
Old Jan 11, 2007 | 08:25 AM
Z-RATED94's Avatar
Yeap, pretty common if your car has some miles on it. Just sold a minivan that made that same noise.
Old Jan 11, 2007 | 11:53 AM
juiceTA's Avatar
i found a busted off spark plug in one b4 from when we did the RE & RE abd busted off the plugs to make it easier lol but b4 that tha heat sheild on the underside of pass. side floor rattled like a biatch and took me 2 seasons to figure it out
Old Jan 11, 2007 | 12:59 PM
2000GTP's Avatar
Jack the car up and check it out. Hopefully you just dropped the heat shield. A defective cat can be costly and more difficult to replace.
Old Jan 11, 2007 | 08:16 PM
apss's Avatar
hit the cat w/the ball of your hand . if it rattles inside ...time for a new cat.
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
jayblev95
Dec 1, 2014 06:55 AM
squarehead
Nov 21, 2014 08:02 PM
StngStlkr
Sep 6, 2002 05:47 PM
