Please help me plan my true duel exhaust
Old Aug 16, 2010 | 12:09 PM
  #16
razor02097's Avatar
No it is not lowered.
Here is what you need to take off in order to get a driver's side Edelbrock long tube header in.
1. manifold
2. Steering shaft
3. plugs and wires
4. wire retainers and all clips holding the wires on
5. oil filter and oil cooler housing (which means drain the coolant.)
6. drop the steering column and retract inside vehicle. (trust me on this)
7. Valve cover
8. Fan temp switch
9. Brake master cylinder (just disconnect and pull to side)
10. Brake booster hose
Header goes in from top
passenger side header
* starter
* spark plugs
* oil dipstick tube
Header goes in from bottom.
If you have a street car you will have to do something about the #8 primary as it will contact the HVAC box. Wrap it or something.
Old Aug 16, 2010 | 01:34 PM
  #17
JakeRobb's Avatar
Super Moderator
Originally Posted by razor02097
The cats are needed to stay in compliance with Ohio law.
Federal law prohibits you from relocating the cats from their original factory location, as well as from modifying them in any way. The only exception is if it's not destined for the street. Longtube headers by definition involve relocation of the cats.
My point is that if you're concerned about being compliant with the law, you're already screwed.
Old Aug 16, 2010 | 01:44 PM
  #18
razor02097's Avatar
I could have a single cat at the factory location with my 94 Heck I could use my factory cat while I'm at it.
Old Aug 31, 2010 | 05:57 PM
  #19
razor02097's Avatar
Here is the progress pics of my off road exhaust thus far...
The last pic they are zip tied together so I can get an idea for mounts and how the will line up in the transmission tunnel. I have since then added said mounts and finished part 1 of the over axle pipes. I have to order a panhard bar relocation kit so I can fit the 2 3" pipes over the axle. I clearanced the spare well so I can fit the full size muffler between it and the T top well. I plan on having a tire repair kit instead of a spare for 3 reasons... it is more useful, less weight and my LS1 front brakes won't work with the factory spare anyway.
Old Jan 23, 2011 | 02:43 PM
  #20
GenIIJR's Avatar
Re: Please help me plan my true duel exhaust
You ever get any finished pics of the over axle pieces? Really interested a similar set up for my car. Any rubbing issues?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Queens94z28
Nov 20, 2014 06:03 PM
guionM
9
Aug 29, 2002 01:48 PM
